OK>.. AFTER much much aggravation ... I have found the PROBLEM... Repaired with non other than a simple TIE WRAP... lol lol..... Just by accident i was looking down and all over the Main wiring harness... WEll..... It seems when the brake pedal is pushed for starting the Mower, the plug for the Brake switch would move .. JUST ENOUGH ... to not make contact.. lol .. SO .. i put a tie wrap around it to stop it from moving and WA LA... everything is working perfectly... Thanks guys .. this a fix for the record books... HA HA HA...
