Kubota ZG227 Stats then dies
Bertrrr
This thing starts for just a few seconds then seems to bind up and falls on it's face , Oil level is good , battery good , I can hear the fuel pump running
Not sure where the Carburator is even located . Will start pulling off panels tomorrow to try and see what's going on.
Wondering if there is a brake grabing the flywheel for some safety thing ,it does not spit and sputter or even try to keep running it just seems to bind up right away
Just seeing if anyone can shed some light on this thing, thanks
Bertrrr
Thanks so much for this
Bertrrr
Found the starter was causing all the problems
