bones66
- May 3, 2011
- 42
............just make sure you keep your mower spindles greased they are expensive to replace. You don't have to grease every time you mow.
My spindles are HOT after mowing is this normal? They won't burn you with a quick touch but you cannot leave your hand on them. I do grease mine about 3-4 pumps every day I use it. I'm probably a little older than most of you so this mean I like to see some grease squirt out from somewhere as an indication that it's properly greased and can stop. I never see any come from anywhere on those spindles??? Should I?
