I don't see any big dents or chips in the blades and it doesn't show that the spindle bolts are moving (might not see that under the grass anyway). You have a mystery here, but breaking in the same place suggests a defect in the blade manufacture.
I'd probably take more good pictures and send the pictures to the blade manufacturer and Kubota. Keep the actual blades for evidence.
This is a dangerous situation and I would think that at least Kubota would want to help you solve the problem.
1)
Sent: Thursday, September 01, 2011 6:21 AM
To: Ken
Subject: Ok, this needs Ken's diagnostic brain
http://www.lawnmowerforum.com/general-mower-discussion/5418-kubota-middle-blade-breaks.html
This is very intriguing to me and I'm at a loss except to think that the blades originally on the mower were inferior and had a design flaw. If anyone can pinpoint a theoretical cause, I think it's you.
So, what do you think? I think it has to be a blade problem but you see stuff like this frequently and might better understand the physics of what would do this.
This is pretty interesting.
Rob
2)
Sent: Thursday, September 01, 2011 11:06 AM
To: Rob
Subject: RE: Ok, this needs Ken's diagnostic brain
The only way it could break in that short of time is from fatigue due to harmonics. His gearbox bearings / gears will be next in line for catastrophic failure.
I am not a member so I can't look at the photos of the breaks.
There was a good suggestion for measuring the blade at 180 degree rotations to see if the quill was bent.
Also, I know this is counter intuitive, but if he ran with a lighter blade this would push the natural frequency up and likely out of the range of the rotational frequency of the mower.
At present, he either needs to slow the motor speed down or speed it up to avoid the critical frequency of the blade.
Ken
-------I copied and emailed him the pics you posted and here's his final reply-------------
3)
Sent: Thursday, September 01, 2011 8:54 AM
To: Ken
[photo of mandril and remaining blade center with bolt looking up]
This tells the story (the guy takes pictures of all the wrong angles!!)
This is a classic fatigue failure from bending UP and DOWN. The original crack started in the dark colored areas and the final failure was a complete fracture (light colored areas).
The original crack had time enough to rust and looks like the crack started on the top surface and propagated downward with would mean the bending was oriented downward at the tip of the blade.
[photo of center of blade and bolt looking down]
This photo shows fretting corrosion.
Not enough clamping force to deal with the vibration of the blade doing the harmonic dance . . .
Also the bolt hole is huge compared to the bolt. Presumably there is a bushing that centers the blade on the shaft / quill . . . if not, that would explain the problem right there.
Ken
REMOVED THE DECK
I removed the mower deck, then the remnant of the middle blade.
The deck is missing a rear wheel and the guard chute.
The middle blade parts I removed seem to be what the manual indicates.
Note that the bottom of the middle shaft has a shoulder on it. The shoulder is the same diameter as the hole in the blade, and the blade slips onto that shoulder.
Now that I have a better view, all three mower pulleys still look to have the same diameter.
I don't feel any wobble in the shafts.
Next I'll put on a middle blade and see if I can detect any runout/wobble.
Indeed! I think it has to be a harmonic issue, exacerbated by a bent quill, that is causing all this. Once again, not being a forensic engineer, it is just a SWAG.That center spindle does turn directly from the PTO gearbox and could be setting up a harmonic because of bad U-joints ??? or bad gears in that gearbox ??? or worn bearings in the spindle ???![]()
The outer spindles would not have all that transfered though the belts.
Does the dealer have any similar experience ?
I'll be interested to know what else you find out !
I have a circa 1989 Kubota B7200 HST with an "RC60-72H" 60-inch belly deck. I started using it April 2008 when it had 846 hours. In Sept. 2010, at 935 hours the middle blade broke. Then again at 956, 960, and 965 hours. So the middle blade has snapped four times - 3 x with old blades, once with a new blade.
The breaks always occur about two inches from the center mounting hole. They are clean breaks, and almost look at though they had been sawed off. Sometimes the blade breaks in one place, sometimes in two places (on either side of the center hole).
I see nothing that the blades could be hitting. The blades are clearing each other, unless a blade shaft is distorting a lot, and I detect no wobble in the shafts.
The middle blade is driven directly by a gearbox, while the outer blades are belt-driven. I wonder if vibration is fatiguing the metal blade. (The outer blades would be cushioned by the belt.) The U-joints from the PTO to the gearbox seem OK, but the U-joints aren't a really tight fit on the splined PTO shaft. I can see the PTO shaft wobbling, but perhaps that's normal due to the action of the U-joints turning. It's not a very long shaft.
Any ideas what's wrong? Anyone ever heard of this?
