KohlerCV20S Starter
tractorman
I removed the starter from Kohler CV20 in the process 2- spacers fell to the floor When I replaced the starter with spacers between starter and engine block the drive gear will not engage flywheel with starter installed without spacers engages ok what am I missing. reason for removing i thought that engine was stuck found that starter drive gear had not retracted any help appreciated. Thanks tractorman
While need the spec number to determine which of the many starters that Kohler has used.
