B Brady S. Forum Newbie Joined Sep 16, 2020 Messages 1 Sep 16, 2020 #1 24 hp starving for fuel. I have replaced fuel pump filter all fuel lines and checked the carburetor float and needle. Help
Scrubcadet10 Lawn Pro Staff member Community Leader Joined Sep 24, 2017 Messages 6,975 Location Conroe Sep 16, 2020 #2 have you cleaned out your gas tank? and was the filter installed the right way both times? (cap towards the carb, open end towards the tank) also try running it with the gas cap loose, the tank may not be venting properly.
