reynoldston
- May 23, 2011
- 92
- 5,705
If the Magnum is anything like the Command(pretty sure they are 98% the same
Enuf.
tom
It more like 98% different not the same engine at all.
Enuf.
tom
I actually don't think the fuel pump was the original problem because it would always start after it cooled down. However this time it wouldn't and after taking the pump apart I noticed one of the one way valves that are pressed into the housing fell out so it wouldn't create a vacuum. Anyway I already had the new pump so I used it and I'll save the old for a spare. I really think the original problem was the overheating because it was really clogged up under there.
