benjaminfisher68
Ok so I screwed up. My PTO clutch wasn't getting 12v to close and get the deck on so I said screw it, found 12v and a ground, ran it through a switch and it turns out the ground I used was the wire going to both coil packs. Long story short, I fried both coil packs, so I replaced them (and plugs), gapped both properly and now when I'm running the engine, it's running rough. Both cylinders are firing but it almost sounds like an issue with timing? I'm convinced I fried something else when I shorted out the Coils, but I can't for the life of me figure out what. I also tried putting in a new voltage regulator and that didn't make a difference. Please help!
