- Feb 19, 2020
- 79
- 10,274
Okay i know some you uses pry bar and BFH but even that don't on this engine. And I got the puller that is list in the service but there is no get it attached. The two larage round holes are for the pins that holds the flywheel fan on and are not be threaded besides they are 5 inches on center the tool is only 3-3/4 on center.
Here is the flywheel.
and here is the puller.
Just how the heck are you suppose to remove the flywheel?
