kohler engine
Shaft 83
Have a new Zt730-3027 23 horse kohler engine . Why is the starter engaging as soon as I hook up the battery cables. Nothing else is hooked up and the switch is off
Scrubcadet10
Moderator
Staff member
I have a feeling the solenoid is jammed/stuck in the closed position...
which starter do you have?
#1 or #2
It will help if we knew which engine you ave and what you are putting it into
