Kohler engine swap
nclintonnick
I have a 2006 Troy Bilt super bronco with a Kohler 19 hp courage with a cracked block. Any info on what I can swap this out with
Any engine you feel like with the same 1" pto shaft and alternator of the same size or larger if you have an electric clutch.
In the past I have had mixed luck with drilling the tip of the crack and filling it with an aluminium repair putty.
I have now got an oxy welding technique down pat & can usually pull it off.
Down here we are looking at $ 2500 to replace the engine + labour.
Staying with Kohler will be the easiest as it is a plug & play swap
Fitting a B & S will require new control wires and some rewiring
Small engine warehouse
Small engine Supplies
Surplus center
are the places I shop for engines.
They stock surplus. over orders factory pulls so are the cheapest engines.
