- Sep 7, 2024
- 3,312
We need the full model and serial number to reference the correct parts catalogues.
This is what typically happens when a coil stops working under stress (load). The engine does not rock or shake, a coil just quits.
A quick test:
Run at high RPM, use a spray bottle and hit each exhaust head pipe with a quick stream of water. The cylinder that is working will burn off the water instantly. The one not working correctly will have a delay burning off the water.
Swap plugs to be sure it is not a plug that is failing and retest with the water. See if the issue switches sides.
Perform a compression test with the throttle in the wide-open position and compare the readings from side to side, they should be pretty close.
This may lead to having to pull the fuel tanks off and flush them out and do a thorough inspection. I've pulled some strange stuff out of fuel tanks like candy wrapper and small plastic bags. Old grass clippings and dirt are pretty common. Just looking down the fill opening is not an "inspection".
A quick test:
