Mothman
- Apr 9, 2021
- 4
- 16
Hi folks,
Got this Craftsman DGT 6000 running to a point, idle only.
Carburetor has been repaired, the accelerator pump diaphragm was shot, bowl o-ring was gone and it was gunked up. It's no longer leaking fuel and all jets/pipes etc are clean.
I can not find any diagrams or references to the way the throttle and choke are hooked up (see photo assembly.jpg) or even if that whole assembly is put together the right way.
What I really need is reference photos from someone that has one of these tractors so I can compare. Both the tractor and engine service manuals only mention the governor arm and not the rest of this assembly. The way it's all put together now is based off glimpses from youtube videos and experimentation.
I've had suggestions that say the fuel mix screw needs to be adjusted; my carburetor doesn't have one of those adjustment screws. Apart from the idle speed, nothing on this carb can be adjusted and it idles fine at 1000rpm. I can get the engine to 2000 rpm sometimes running smooth-ish (with choke wide open) but as soon as I drive with it, it starts stuttering and is about to stall unless I bring it back to 1000rpm. There is also a line that leads from one of the cylinder heads to underneath the air filter, that is leaking a LOT (I think it's fuel), don't know what it's called but a photo has been attached (leaking.jpg).
I don't know where to look next as I know next to nothing about engines/carbs and the likes. Mower repair shops can't come out til the end of July which doesn't help me now either so decided to just keep at it myself
Additional info (may be relevant or not):
- Fuel filter was replaced, old one was gunked up.
- All the original fuel hoses are in place, no leaks or deterioration that I can see
- Fuel tank cap breather works
- New spark plugs do not improve or worsen the situation
Hoping someone can help me make sense of this.
Thanks!
Thanks!
