Kohler CV15s idles with choke on, then as you take it off choke and tries to run a little faster, it starts backfiring and dies. Has new spark plug, spark looks good, carbs been cleaned, gas is clean, coil gapped at .010. Started up and worked fine after sitting for the winter, then when I tried to start it and put it away it had the problem. I did a compression tested and got 190 after a few spins. Not sure what else to check. I don't know much about this stuff, so any ideas are welcomed.
Dan
Dan
