ukwildcat53
- Feb 24, 2017
- Threads
- 3
- 18
I have a Kohler Courage SV715s engine built in 2007. I have been having trouble for the last couple of years getting it started. If it will crank it starts easily but I cannot it is very hard to get it to turn over. I have read about the automatic compression release being a problem. I have adjusted the valves because everyone says that is the first thing to check. I have cleaned battery connections. I have replaced the battery. If I remove the spark plugs the engine spins easily with the starter. I have looked at the service manual and it says that this engine has ACR but I can't find anything about it. Some engines have a spring and weight but I don't see that setup on this engine. Is the ACR just a lobe on the cam or how does it work? Any help would be appreciated. Thanks.
