Hello from Southwest Florida. I have a problem with my Toro ss4235. My area had some flooding during Hurricane Ian. My area hasn't flooded in 22 years living here. I've just been lucky. I have a split-level lot, my house is on higher ground, my shed sits about 30" lower where my mower is stored. The storm moved in, and my mower sat in about a foot of water for 3 days, this included the lower half of the motor. I finally got it moved to my carport and replaced the brake control module, the solenoid, the starter and battery. when I tried to start it I got about a half cup of water out of the exhaust. The motor turned over but no spark. I do have an oil change kit. When I drained the oil, I got roughly a half inch of water out of the case with the oil in a 3" diameter can. I've searched high and low on YouTube and several other sites. From the results I got it seems this has never happened before. Then I found LawnWorld and decided to try finding an answer on how to flush any remaining water out of the engine block. Any suggestions will certainly be appreciated.
