kevicarlson
- Jan 21, 2013
- 4
- 9
Initially the valve casket was leaking which I replaced and it ran well for a few months. Then it began spitting oil out of the breather tube and there was gas in the crankcase with the oil.
Next step was carb rebuild, no luck, installed new carb still not luck but it stopped the gas spitting from muffler on start. Poking around on the forum
I suspect it is a number of things but what is most logical starting point? I have no evidence the block is cracked.
Valve adjustment
Head gasket replacement
Piston rings
Breather reed broken?
Model kohler courage sv590 19 hp, about 6 yrs old. I get the sense not the most favored engine but here I am.
Thanks
Valve adjustment
Piston rings
Thanks
