Well to start off I have a Kohler Courage 20hp single cam motor and that thing has been a POS since I owned it ; from missing internal components not installed at factory, to replacing the carburetor, and other problems this thing has been a nightmare but I cant afford another tractor.
So to start off with my current problem, imagine going along your day cutting the grass peacefully when all of the sudden you start to lose power- you think ok I am running out of gas so I should start heading back to the garage to fill her up, then all of a sudden the power drops suddenly and make such a loud vibrating noise from the engine and so you turned off the engine and pushed her back and you let her sit for a couple of hours.
Well I came back after letting her sit, I tried to turn her again but she was still making that noise, so I starting checking things off until I come to notice that the was dry and all I can say oh s*** and especially knowing that she was full before I started. So that's my problem an unknown noise (not a mechanic so don't recognize the sounds)
What I did though to calm some worry was I turned the fuel valve off (gravity fed) and pulled the spark plug boot, and turned her over; which she turns over fine no clinks no rattles no scrapping of any kind and there is compression. But when she starts it sounds like plastic in a nitro powered blender with some bad vibrating to it :thumbdown:
