Kohler Courage Engine (MTD GOLD Rider) Oil leaking from bottom
Scheduled service fee says 4 hours + parts.
That is for warranty work so assumes everything comes out easy the workshop has all of the special tools on hand & the engine is fairly well clean.
I don't know where you are getting 4 hours for warranty when the 4/19 Kohler warranty guidelines show .3 for replacement of the seal and 1.0 for R & R engine. So unless you have something special to remove and get to the seal 1.3 is all you are getting from Kohler
Sounds like the oil seal has failed.
Engine removal is probably needed for replacement.
Any mower repair shop can/should do it.
There are tons of videos on seal replacement on youtube.
Sticking my nose in here....is there a cover plate, for a (or the) cam shaft, with an o-ring fir a seal on this engine?
