Kohler Courage 25 HP
I got just got a similar reply so they are aware of the problems and working on it which is good for us techs that depends on the system.
In reference to #1 – we are updating specs that currently show no image available and have just a list of parts
In reference to #2 – the system has limitations as it auto populates options to pick from – we are aware of this issue and are looking for a resolution. Searching by serial number and full spec number will give the best results.
We hope to have both issues resolved before the end of the year when Kohler PLUS is turned off.
Hcube
Thanks to all who checked for a solution. I will pursue this further.
Oh I forgot to mention that I have a black cloud over me and I always
get the one that will have problems, are is different from anyone else .
My computer has a different screen that what some one else's. I pick the wrong lines at the gas station and at the grocery store, etc.
Best wishes,
Hcube
hlw49
SV730-0033 does not have a compression release on the cam. You can put the starter off a cv25 on it. It is designed to crank an engine without a compression release. works
