- Nov 29, 2014
- 24,995
I have a 6 year old Cub with the 20hp Kohler Courage engine and at about 150 hours it developed a knock at lower speeds with no load, I tightened all of the mounting bolts and the noise still persisted until this last weekend....Half way thru my lawn mowing experience the noise got louder I shut it off checked to see that the oil was still full, no lights on, started mowing again, suddenly the noise got even louder. Before I could get it back to the garage it started losing power and oil was being sprayed everywhere. After it cooled down I did an autopsy only to find several bolts were loose on the top plate under the flywheel, the game changer came when i discovered a 4" crack from the area of the loose bolts down the exhaust side of the block and cylinder jug....It seems the most prudent repair was to order a new short block assembly for $400. plus a gasket set. I will let you know it it will live again to mow another day. Seems like a shame that if the top plate bolts coming loose at low hours would lead to this disaster that someone might notify the owners of the affected engines so it could be fixed before it is too late...
That is what we call the Kohler Krack and is very common.
Usually happens to owners who mow large areas regularly so the engine runs for long spells at a constant speed.
IMHO it is because the Courage is a downgraded version of the Command and has a much larger & heavier cast malleable iron crank comparred to the Commands lighter, thinner & stronger forged crank.
The crank can represent up to 1/2 the entire cost of making an engine and casting is the cheapest form of shaping metal, thus the cast crank.
I get 1 some times 2 a season and have had some success with drilling the root and using an epoxy filler like JB weld or Devcon, about 4 in 5 seem to be happy like this.
Check the counter weight very carefully as the crack is oft associated with a broken or loose bolt that holds the counter weight halves together,
If you are mechanically minded, a short block will be a better fix.
You can also get the cases welded.
Gas welding seems to work a lot better than arc welding.
I charge $ 200 ( AUS) to weld one as I can usually do it in situ without dissmanteling the engine.
Bogging is a $ 100 fix with no guarantee as there is a bit over an hour in it by the time I have checked the internals, bogged the crack & replaced the gasket.
If you take it to a welding shop they will need the bare case & top plate, should come to $ 40 to $ 100.
OTOH places like Small Engine Warehouse , Small Engine Supplies, Repower etc ( find them on the links section ) usually can do an equivalent engine for $ 400 to $ 600 .
Then you can either break down your old mower for parts, or keep some spares.
A piston, rod, alterantor, flywheel , rectifier, coil, starter & carb sold as parts can come to way more than an entire new engine.
