- Nov 29, 2014
- 65
- 24,995
SteelStik seems to be holding, haven't gave it a hot test yet.......
In the early days I tried JB weld mostly it held up but did weep a little if you drill 1/4" in front of the crack to stop it propogating.
I had a customer come in complaining that the mower would stop after 2-3 hours mowing and this was because the crack opened up far enough for the fuel pump to stop working.
The welding shop wanted the bare cases & for $50 did MIG weld which I then had to dress flat , the reassemble the engine & refit it to the frame which came out at around $ 800 so that was off the cards.
Next trick was Devcon.
It is magic and works very well but you really have to clean the crack then hit the cases with stainless steel wire wool or it wont take, and again drill the crack tip.
This comes out at around $ 400 including the new studs .
Had some time to play with the oxy so now can weld the crack and that comes out at $ 300 .
Time will tell how good they were
