Suzie
- May 22, 2020
- 7
I have a kohler courage 19 Sv470-610 vertical crankshaft, my question is - the bolts that hold the engine on the mower frame, I call them motor mount,, bolts are there one of them on the left front attached to the i guess idler pulley that the transmission belt goes around?? It is the pulley that releases the tension on the belt.. hope I worded that right so someone can understand I know a lot about looking and working on the mower just don't know all the names of parts.Thank you in advance... suzie
