Kohler courage 19 counterweight bearings?
IT is actually tin, aluminium and antimony and most likely indium plated.
Should be lots of those Kohlers around with split cases.
Most likely form a mower bone yard
Scrubcadet10
Moderator
Staff member
On yeah, I'm sure there lots of used parts off of those engines.
My cub cadet has the courage 19, thankfully 9 years and still going strong.
But I always check for the problem areas, sump bolts loosening leaky valve cover etc, so far none of that.:thumbsup:
dniksich
Gonna try looking around my area to see if I can find something. Yeah, with cracking blocks being so common I'd think it would be easy to find.
