JDgreen
Kohler has had problems with the diaphragm that is suppose to open the choke partway until the engines warms up and the other choke finishs opening it. Kohler is well aware of the needle valve issue with the carb built from serial number 37XXXXXXX something to 39XXXXXXXX something and if your engine falls within the specified by the kohler bulletin the dealers are replacing the carb or needle valve under warranty per Kohler instructions.
Thanks for the info put my Kohler engine mower away an hour ago gonna run out and check the number now....oh crud my engine begins with 38 and the warranty has probably expired by now. Thanks for the heads up.
