- Sep 7, 2024
- Threads
- 9
- 762
You can also disconnect the line on the carburetor and place the end of the line in a jar, plastic soda bottle or plastic cup (do not use a Styrofoam cup), then crank the engine to verify it is actually pumping fuel.
Watching the filter while cranking is not reliable, because they do not typically fill up with fuel. Once running at higher RPM, they filter may fill up eventually.
Can you attach a picture of your replacement pump as it is mounted?
