Thanks for the help in my other thread. New problem is the mower wants to quit running after cutting for a while, acts like it is running out of gas. Stops and starts righ back up, and then in a little while does the same thing again. Filter seems to have gas in it when it stops. One other question, if you pull the oil fill cap off during the motor running do you get air and maybe suction out of the fill hole on the valve cover?Any help here.
Thanks
Ray :confused2:
			Thanks
Ray :confused2:
