Kohler ch20 engine
Kohler20
My Kohler ch20 motor has oil running out of the exhaust muffler. It will run but leaks to bad to keep running
Scrubcadet10
Moderator
Staff member
Check your oil level on the dipstick, if it is over full, check that it doesn't smell like gasoline or is thinned out.
Dip the oil and see if it is above the full mark.
If so smell it a see if it smells like fuel
