I have the above engine (Spec No. KT745-3066, 2016 mfg date, 270hrs) that's giving me issues. The problem first showed up as a loss of power; after inspecting spark plugs, I realized it was only running on one cylinder. New plug and coil later, still no spark. If I remove the white wire that plugs into the coil (I've heard it called a ground, and a 'kill wire'...idk what it is, honestly) I have spark, and engine runs correctly...full power, blades, everything.
Separate issue (but I believe must be connected): engine will not start at all, unless choke is applied...in which case, it fires right up, just as it's supposed to.
Also, not sure if it makes any difference in terms of diagnostics, but the engine is powering a 2016 Craftsman G8400 ride-on tractor.
Really, I'm just stumped at this point. Any help would be appreciated!
