Probably the least likely reason the fuse blew but the easiest to rule out would be an over charging situation. If you have a voltmeter check the voltage at the battery with the engine running at full speed. It should be between 13.8 and 14.7 VDC.Simplest thing worked. Blown 20 amp yellow fuse. Why did that fuse go? If the new goes, what do I check next? Maybe I’m getting ahead of myself
