kohler 26 hpv twin change oil light flashing
FUNKFN6
i changed the oil and filter in my mower the hour meter flashs cng oil thought i got a bad filter changed it again mower got rained on pretty good last nightany body got an idea why???
It will flash for about 15 mins every time you start
It will do this for two hours then will reset it self
It should do this every 50 hours
(( racing is the only sport that you need two balls ))
There hould be a reset button on back of hr meter or fuse panel , if not unplug battery both positive and negative than hold two together to drain capacitor and it should reset oil change light.
