sofasurfer
- Jun 1, 2020
- 64
Kohler (Courage?) 24hp, 2009 or 2010. The drive pullet under the engine is full of oil. I assume this is a bad seal. I hope this is an easy repair. Problem is, I saw a post that had the same issue but the problem was that the inner case, where the crank rests was worn thus causing the seal to go bad. I think that was a 2002 engine. Hopefully my 2010 does not have that issue. Anyway, does this sound like a seal issue to you? I looked at the parts diagram and it appears that the seal is on the outside of the engine.
Hoping for some good thoughts.
