Kohler 22 hp courage how to remove crankshaft
Lurlin
I am trying to remove crankshaft on kohler courage 22hp
Lurlin
The model # sv620-0018. The crankshaft will not turn even with added force. I have the engine torn down to the crankshaft. Is there abolt to remove yet?
Lurlin
Ive got the top plate off and the cams removed. Tring to remove crankshaft. Does it just pull up to remove it?
Have you removed the flywheel? Have you removed the connecting rod? Have you looked at the manual, section on engine disassembly?
Lurlin
Thank you for that manual figured it out .
