I am trying to remove crankshaft on kohler courage 22hp
Lurlin Forum Newbie Joined Jul 3, 2022 Threads 1 Messages 4 Jul 4, 2022 / Kohler 22 hp courage how to remove crankshaft #1 I am trying to remove crankshaft on kohler courage 22hp
Lurlin Forum Newbie Joined Jul 3, 2022 Threads 1 Messages 4 Jul 4, 2022 / Kohler 22 hp courage how to remove crankshaft #2 The model # sv620-0018. The crankshaft will not turn even with added force. I have the engine torn down to the crankshaft. Is there abolt to remove yet?
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,683 Jul 4, 2022 / Kohler 22 hp courage how to remove crankshaft #3 We don’t know what you mean by”torn down”? This means different things to different people. This service manual may be of some help to you. If you can’t get it out, post some pics so we can see how far you have torn it down. https://www.mymowerparts.com/pdf/Ko...urage-SV470-SV480-SV530-SV540-SV590-SV600.pdf
Lurlin Forum Newbie Joined Jul 3, 2022 Threads 1 Messages 4 Jul 4, 2022 / Kohler 22 hp courage how to remove crankshaft #4 Ive got the top plate off and the cams removed. Tring to remove crankshaft. Does it just pull up to remove it?
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,683 Jul 4, 2022 / Kohler 22 hp courage how to remove crankshaft #5 Have you removed the flywheel? Have you removed the connecting rod? Have you looked at the manual, section on engine disassembly?
Lurlin Forum Newbie Joined Jul 3, 2022 Threads 1 Messages 4 Jul 4, 2022 / Kohler 22 hp courage how to remove crankshaft #6 Thank you for that manual figured it out .
