When I turn on key it would do a clicking sound which is normal, then I would hold key till glow plugs light went out and the proceed to start, and it worked.
I noticed with the key turned off I could here that clicking one in a while when tractor was not in use! Then I started having trouble getting the starter to kick in, I just kept re trying the key and it would eventually start. Now I have to short out the solenoid with a screwdriver to start it.
I have no lights or gauges working on the dash. I checked all the fuses and did all the electrical plugs with electrical contact lube and made no difference.
Can someone tell me what to do to correct this problem, also I can't get the ignition switch out of the dash, the hold down nut is off but it won't push out of the dash????
I'm thinking that it could be a not proper ground, has anyone had this problem?
Thanks for any help offered.
Paul
Paul
