Knock-off oil filters
kennny1976
I ordered a Amazon oil filter to replace my Kawasaki 49065-7010 oil filter which goes on my Scag Wildcat (Kawasaki engine FD731V).
Now I am a little concerned if it is as good as the original Kawasaki brand? It says "made in China". Any comments?
MParr
Why didn't you just go to Walmart and get a FRAM TG4967?
Because the OP probably didn't know it was a cross. Not every cross is noted on many sites.
But many China filters are just as good as American ones; although, I prefer using American products when they are priced reasonable. Just like I prefer local purchases whenever I can but being a business I have to stay competitive priced too so I use distributors for purchases.
And just like Chinese products can be junk so can American products, just depends on the quality control of the products. And some of the Chinese products I use here are actually better than the American product or even OEM product. Just to do your research.
MParr
Exactly! Microgard Select, from O'Reilly Auto Parts, and NAPA Gold are sourced from either China or Vietnam. NAPA dropped WIX as a supplier because the quality dropped off.
Skippydiesel
Thoughts On The Matter:
Problem with filters (especially the spin-on/enclosed kind) is that the end user (us) do not have the equipment, technical expertees to make an informed judgement as to how effective the filter is.
As others have noted, where the filter is made has little bearing on its quality (quality, in this instance, being how well it filters, while allowing good fuel/air/oil flow).
Standards met and the availability of specifications, is your best method for determining quality. Unfortunatly such information can be hard to find or completely absent.
A further angst for the consumer is that your filter supplier may, without notice, change manufacture - the filter costs & looks the same but does it meet the same standards????
Flow Restriction;
This is not such a big deal for fuel & air ie little if any damage will result and the effects should be obvious to the machine operator. Oil filtration is another matter - The effect of restricted oil flow could be catastrophic. If you are operating a sophisticated machine you may have gauges that show oil temperature/pressure and or warning lights, so timely intervention may save your engine. Most of us don't have this level of sophistication, so the first sign of restricted oil flow, may be overheating or even a seized engine.
Ineffective Filtration;
Probably not a serious problem for oil & fuel. An air filter that is not doing its job could quickly lead to a "dusted" engine. Damaged rings & bore may result in costly repairs/replacement.
In summary;
Purchase filters from well known brands, who likly value their reputation.
Fuel filters - If possible use gauze filters that can be inspected and/or serviced - check regularly. Filter fuel into tank.
Air filters - Check regularly for contamination build up. Service/Replace as needed (not necessarily at set intervals)
Oil filters - Do your best. Replace at recommended intervals.
:devilish:
Tiger Small Engine
Flow Restriction;
In summary;
:devilish:
An oil filter is a good example of quality of product, price, and where it is made. I use Briggs and Stratton oil filters that are bought in bulk. Are these made in USA or China? Many parts these days are made in China and the quality has greatly improved over the years. I would obviously rather buy American products, however, not as much is made here, and the price is often not competitive.
Skippydiesel
No offence intended Tiger but your logic is wanting.
Oil (all engine) filters are made all over the developed World, to engine maker specifications, branded (ie painted, serial number, etc) according to the contract (Engine maker, Filter Supply Company, etc). Price & adherence to design specifications being the primary factors.This is the nature of a competitive, open economy - no national allegiance.
B&S most likly source their filters from many suppliers.
As I said earlier - purchasing from a known, reputable brand is your best bet, in the hope that the owner of the Brand (B&S) will value their reputation, so go the extra mile in quality control. :devilish:
Is this a setup post? Really have to ask that question?
If you just want to chit-chat then visit your local nursing home. Those good folks will appreciate it.
Auto Doc's
Ideally it is best to go with OE when possible. Many large lumber/hardware suppliers carry genuine filters if they also sell the mowers.
Amazon is a world product dumping ground mixed with good and bad, and you take your chances. I draw the line by getting genuine filters off of Ebay. The key word is genuine. Otherwise, I get them from a local NAPA.
I also get many filters through Baldwin brand with my local AG supplier.
MParr
OE filters are usually of lower quality and cost more. They are often the entry level or jobber filters. OE filters are made by major manufacturers and painted a different color. You are correct about buying from Ebay or Amazon. When buying from Ebay or Amazon, one must check the seller. Hydraulic filters and air filters are a whole different subject. In those cases the OE filters or those supplied by Stens or Rotary are the best options.
