Key will not shut off mower.
jvancaster
Hi, I am new to this forum and need some help. I own a Scag SWZV36A walk behind mower. The year is a 2008. It starts up fine but when I turn the key to shut it off it will not shut off. It is a manual pull start. I have checked the key switch and it checks out OK with and ohm meter. It also has the senso touch handle bar that does not seem to be working. I was wondering it the two are connected to my problem. Any help would be greatly appreciated. Thanks.
broken kill wire to the coil, bad ground, bad key switch, loose connection, could be a number of different things
