You can do the same on the generator because it is governed .
However in Amal parlance . the replacement carb has to have an equivalent needle jet so it accelerates quickly under load or you end up burning out whatever is connected
Thanks have rejetted a few in the past MXd a couple Pursangs and a BonnevilleYou can do the same on the generator because it is governed .
Didn't MX the Bonnie just rode itThanks have rejetted a few in the past MXd a couple Pursangs and a Bonneville
