Update:  Fresh gas, new bushing, new fuel lines and it seemed to run well (not being too hopeful).  It did hiccup once but that was it.   It doesn't run well at low throttle so there may still be some gremlins...need to look at fuel pump line from crankcase to see if it has any cracks.   My fuel transfer test didn't show any issues, it moved about a quart of gas in under 2 minutes which seems more than ample.  My testing with the hillbilly setup shows it uses about a pint every 15 minutes, or 1 gallon per hour.
