Kawasaki fr651
Carscw
This is what I have found on the valves
Do I set them at TDC?
Can I do them like I do a Briggs one valve open and one closed?
First Kawasaki I have had. Started getting a puff of smoke just on start up. And not every time.
gainestruk
Didn't get the picture Carscw, just a screen shot of phone.
motoman
The puff might simply be a little oil pulled down valve guide with throttle closed at shutdown from high idle. Seals on guides?
Carscw
Smoked all the time now.
About half a quart of oil every hour.
But still has no loss of power.
Did not do a compression test yet. But both sides we'll blow my thumb off the plug hole.
7394
Are the spark plugs showing burnt oil ?
Carscw
Yes just on #2 cylinder
Was wet with oil.
I know blue smoke all the time could be rings.
But no loss of power makes me think not.
Maybe a valve guide?
motoman
If smoke under load, rings/bore. If on throttle after coast, maybe guides. Sensation of power can exist with bad rings.
