Kawasaki FR651 valve seals replacement.
No need to pull heads. Was just wanting advice on ”while you are in there” jobs. I don’t want to be stripping things twice. 500hrs is not a new engine but it’s certainly not at the end of service life and this machine has been looked after and want to keep it that way. Eg if there is a known issue with valves after 500 and the should be replaced I’m happy to do that now rather than wait for a failure but appears best advice is leave it alone.
