Mad_mat222
- Jul 12, 2019
- 17
- 68
My engine installled on a Hustler has just over 500hrs on it and is starting to burn oil. It’s a little smokey at start up and I’m guessing the valve seals need replacing. This is my work machine so I don’t want anymore downtime than necessary but my question is: should I do anything else while the heads are off and the seals are replaced? There is nothing wrong with the performance and only asking in case this would be an advantageous time to do a freshen up. And if I can order parts in advance because there are known issues, would also save the downtime.
Welcome the advice.
cheers
mat
Welcome the advice.
cheers
mat
