Kawasaki FD791D Issues .
Okay what you got is the DFI system and instead of crank position sensor it is using a speed sensory system. IF the Op would like a copy of the SM I send a link via PM to the one that I can temporary upload to my Google drive.
You will a fuel pressure of 25.6 ± 0.7 psi. Also speed sensor may not sending the signal to ECU. Hint the speed sensor is part of ignition coil kill circuit.
cableguy52
Thanks for the info. Is it using both coils or just one.
Both as they are tied together.
MLG (MIG) pin of ECU
ECU PIN OUT
cableguy52
Shows a diode in line. Cant seem to locate. Any ideas where its located? Have the wiring diagrams but thanks for posting.
I don't see doide, just a male and female connector set. Probably Bullet sytle.
cableguy52
You are correct, no diode. Checked coil kill circuit, seems to be functioning properly. This one is a stumper !
jeff Fleming
Did you ever fig out what was wrong? I have the same motor with the same problem
cableguy52
Back to the FD791D. Replaced coils , { thanks for the info} engine now starts but runs rough. Disco the . Vacuum Pressure Sensor, engine runs much better, replaced pressure switch and vacuum tube, same problem. Any ideas!!
