- Feb 19, 2020
- Threads
- 121
- 12,890
Okay what you got is the DFI system and instead of crank position sensor it is using a speed sensory system. IF the Op would like a copy of the SM I send a link via PM to the one that I can temporary upload to my Google drive.
You will a fuel pressure of 25.6 ± 0.7 psi. Also speed sensor may not sending the signal to ECU. Hint the speed sensor is part of ignition coil kill circuit.
