- May 6, 2010
- 51
- 11,390
Shipping delayed. Suppose to be here tomorrow. OEM pump.Did the fuel pump help?
The last 3 Kawasaki engines that I tried Champion plugs in wouldn't start hot. I won't touch another Champion if I can avoid them.JD X350 with 180 hrs. running so bad while mowing i didn't think it would make it back to the shop . Pulled original plugs and replaced with what the Auto supplier referenced the NGK to Champion that I ask for . I;ve never had a engine start so fast when the 1st piston went to compression .
Fuel pump replaced but no change in running. I am going to try to swap the carb when it gets here Monday and see what happens. I did test the pump I took off and it wouldn't hold pressureDid you replace fuel pump yet? If so what was the outcome?
Got the Amazon carb installed, which is not my desired choice, due to quality control in most cases, but anyway the new carb allowed the engine to fire up and run smooth from full throttle down to an idle, which would never idle before, and will even fire back up without the choke applied. So there is definitely something goofy about the carb.Fuel pump replaced but no change in running. I am going to try to swap the carb when it gets here Monday and see what happens. I did test the pump I took off and it wouldn't hold pressure
Yup yup.Got the Amazon carb installed, which is not my desired choice,
