Hi guys. I recently swapped a Kawasaki fc420v es10 es10 off a JD rider and installed on a walk behind. My question is, the newly installed engine does not have an ignition module, despite starting in 3 pulls. Realizing there was no force upon the engine ( belts or transmission), does this engine need an ignition module to properly run? Thanks much.
