Hello guys I am new to the forum. Hopefully someone can help me :smile:
I just acquired an older Husqvarna YTH1542XP, for free :biggrin:
It has a Kawasaki 15hp xp series engine, and it starts up great. However, it smokes enough white/bluish smoke to clear mosquitos for miles.
The guy that gave it to me said the rings are worn out and need to be replaced. Now, I have done a little research and have found that rings aren't always the issue.
Clogged breather? Bad fuel pump?
I don't know where the breather or fuel pump is so I have not checked or diagnosed anything.
The tractor has 1001 hours on it. Would it be worth fixing or should I just replace the entire engine?
Thanks for any insight, looking forward to hearing responses.
