Kawasaki Engine Oil/Fuel issue
MrPlow
Hello guys I am new to the forum. Hopefully someone can help me :smile:
I just acquired an older Husqvarna YTH1542XP, for free :biggrin:
It has a Kawasaki 15hp xp series engine, and it starts up great. However, it smokes enough white/bluish smoke to clear mosquitos for miles.
The guy that gave it to me said the rings are worn out and need to be replaced. Now, I have done a little research and have found that rings aren't always the issue.
Clogged breather? Bad fuel pump?
I don't know where the breather or fuel pump is so I have not checked or diagnosed anything.
The tractor has 1001 hours on it. Would it be worth fixing or should I just replace the entire engine?
Thanks for any insight, looking forward to hearing responses.
With over 1000 hours I would say it probably needs more than just rings. I would look more at just replacing the engine if the rest of the mower is in good condition.
MrPlow
Most likely, I will replace the engine.
But before I drop $400 on a new B&S, I would like to try cheaper alternatives to fixing the engine; such as checking the breather and fuel pump.
Can someone tell me where these are located?
It would be great if it were just a simple issue.
does the smoke go away after a few minutes might also be valve guides just look at everything befor you decide
MrPlow
Smoke does not go away.
Do you guys think taking every apart and giving the insides a good cleaning will help? With 1001 hours, there's got to be a lot of carbon and gunk built up.
I personaly would love to tear this engine apart with my team. I would use it as a learning tool. I work for the university of arkansas, when i started I took two "condemend" engines and made them "sing" again
MrPlow
That's what it looks like im doing in the next week or two. Can't wait to find all of the goodies inside :laughing:
In the mean time, I need to find an engine to slap on the tractor so I can plow.
SONOFADOCKER
Make sure the engine is not fouled with gasoline - this will make the same white oily smoke
reynoldston
If you can drop in a Briggs for 400 dollars you should do it. Parts for a Kawasaki are very expensive and to do a PROPER overhaul it will cost way more then 400 dollars. The only problem you are going to have is that going from a Kawasaki to a B&S you are going to find nothing fits right. Also breather and fuel pump has nothing to do with burning oil but sure wouldn't hurt to check them being a very simple job. When I say a proper OH that includes machine shop work but when you are done it will be as good as new and plan on spending money. Also maybe you could find a good used Kawasaki engine at a mower salvage yard.
MrPlow
The Kawasaki was toast.
After some fresh oil, it started producing a knock and then it finally went.
If I wanted to rebuild it, I could as I have all of the tools and machinery to do so but I won't be doing that.
I have two Briggs' sitting around and I'm putting one on now as we speak.
