Thanks Max, this is a single cylinder, the model is FC540V. I don't think it has valve guides, I believe those are built in to the cylinder head and if they are worn the whole cylinder head has to be replaced. Please check that model yourself and let me know if I'm wrong about that. There are oil seals on the valve stems, I can check and replace those, about $8 for a pair. I can probably pick up the used cylinder head/valves/valve cover assembly for $20 or $30. I guess I hope it is the $8 valve guides, that will make me feel great about removing the engine, splitting the case and spending $100 on the piston rings, oil seal and crankcase gasket that I never needed!
By the way, I made a leak down tester and rather than use the broken spark plug trick I picked up a spark plug non fouler at the auto parts store, it has threaded female end so i used JB Weld to attach that to the smaller sized threaded male end of the air hose. It worked great and was super simple to make.
