I did a leak down test. The air in was running at 90 psi and the air going in held at 80 psi. No air sounding in the intake or exhaust. I could hear air going into the crankcase through the oil filler tube. I held my hand over the tube and felt very little pressure but could hear the air rush out when I removes my hand. From what I read a 10% reduction was acceptable.
I noticed my oil was pretty thin. I suspect some gas got into the oil before I replaced the carburetor. The oil did not smell strongly of gas and it would not ignite with a lighter but it was thin.
My exhaust valve was loose again so I reset it. I have had trouble with the valves loosening, not sure why.
I plan to put some frsh oil in it and see if that makes any difference.
Any suggestions?
Any suggestions?
